mritchey
    5
Reputation
0 Neutral
Personal Information
  • Location
    Los Angeles
  1. It turns out in my Template (and most of my files) I had the class "None" turned off. Of course, even if you assign the object to a different class, some part of it is still assigned to "None." Since I had the visibility turned off, it would not show up. But as soon as I turned the "None" class on, it worked right away!
  2. Hey Everyone, I am trying to insert lighting positions from the resource browser, but when I import them nothing is displayed. I can select the object, and it tells me that it is a 2D/3D Symbol and I am able to edit it, but I cannot actually see it (plan or 3D views). I'm sure it is something that I did by mistake, but I have no idea what. Any help would be greatly appreciated! Thanks, Mike
  3. Where is the Library of the speakers you create located? Or is there anyway to edit and remove devices from the library? Thanks for the help!
  4. The Align Layer Views worked perfectly for that. Thanks a lot for the help.
  5. I am working with Vectorworks 2010 on a Macbook Pro. I am having issues where my layers are behaving very weirdly. The reference grids are not the right scale, I can't convert lines to Light Positions, etc. All the layers have the same settings. The only difference I noticed was when I was switching layers in the Object Info Pallet. In the drop down menu, the layers that are behaving correctly have nothing next to them. The layers that aren't working have some sorts of symbols next to them. I will try to attach a picture of it. If anyone knows what is happening and has a solution, I would really appreciate the help. Thanks, Mike In the Photo, Lineset Hang works, the ones with other stuff next to it does not.
