Andrew Neilson
8 -
Reputation
0 NeutralPersonal Information
Occupation
Drafting & Design
Location
Canada
Seeking a Database formula for a Worksheet that will call up a SYMBOL with a RECORD and a PLUG-IN inside the symbol AND report them as a single instance in the DATABASE. What I'm trying to get is a single instance of the object in the DATABASE where I can put Criteria in columns from both the Record attached to symbol and the Plug-in inside the symbol. Closest I get is a database reporting both the Plug-in and the Symbol. Specifics: I'd like to have a window plug-in as a symbol (W-01) which repeats throughout the project. Want to pull Symbol Record info and Plug-in Info from inside the symbol in the Database row. The Record attached to the Symbol will contain specific info for each instance of (W-01). IE the North/South/East/West direction, wall type & Sill, Jamb and Head Detail # as they vary for each instance of (W-01). The Plug-in contains the width, height ect. which i'd like displayed in the same Worksheet. Ideas ??? - my solution to date is 2 Worksheets, one reporting the record and the other reporting Plug-in inside the symbol. The symbol and plug-in have matching IDs (W-01) which are sorted. The worksheets are overlapped beside each other to create one big Window Schedule. - Any ideas or alternate solutions people are using would be appreciated! -Should I give up? Is a window the same size and type but different wall, sill, head and jamb - Simply another window type? - Architectural drafting convention?
Using the Script below to rename classes. Works great - but realized its changing the class setting to 'default' black pen, white fill, lineweight of 1 ect. What could I remove/add from the script so that renamed class retains the same settings as the old one? ~A PROCEDURE RenameClassName; CONST kTOT_CLASS = 300; VAR i: INTEGER; curClass: STRING; oldList: ARRAY[1..kTOT_CLASS] OF STRING; newList: ARRAY[1..kTOT_CLASS] OF STRING; PROCEDURE ChangeName(objHdl: HANDLE); BEGIN SetClass(objHdl,newList); END; BEGIN oldList[1]:= 'WDA-Ext Door-Color 1'; newList[1]:= 'WDA-Ext Door-01'; FOR i:= 1 TO kTOT_CLASS DO BEGIN curClass:= oldList; ForEachObject(ChangeName,(INSYMBOL & INOBJECT & INVIEWPORT & (C=curClass))); IF Len(curClass) > 0 THEN DelClass(curClass); END; END; Run(RenameClassName);
Script to draw line with preset object name?
Andrew Neilson replied to Andrew Neilson's topic in Vectorscript
Both Pat & Peter's scripts do what I was hoping for. Thanks fellas! Sorry I'm no help with 'LNewObj' verus 'LObject' differences... With regard to Pat's point: "I am using Date(2,2) to generate a unique string since only a single object in the drawing can have a specific name, it just makes it easier to test without having to remember to delete the named object before running the script." Is there some way I could have the script bleep out "This name is already in use. Reverting to old name." just as VectorWorks does when one tries to name an object with a name already existing in the file. Thank-you all for your help! -
Thanks Miguel & Raymond, I've got the following working as an example, which changes objects classed as 'A' to 'Z'. Unfortunately its not working on objects in symbols. How might I modify this to include objects inside symbols? PROCEDURE RenameClassName; CONST kTOT_CLASS = 50; VAR i: INTEGER; curClass: STRING; oldList: ARRAY[1..kTOT_CLASS] OF STRING; newList: ARRAY[1..kTOT_CLASS] OF STRING; PROCEDURE ChangeName(objHdl: HANDLE); BEGIN SetClass(objHdl,newList); END; BEGIN oldList[1]:= 'A'; newList[1]:= 'Z'; FOR i:= 1 TO kTOT_CLASS DO BEGIN curClass:= oldList; ForEachObject(ChangeName,((C=curClass))); END; END; Run(RenameClassName);
Hi Miguel, This looks very promising but keeps returning the following error: Line #9: newList: ARRAY[1..kTOT_CLASS] OF STRING: | { Error: Expected ; } | { Error: Expected BEGIN } Thanks so much for the help!
I'd like to rename a classes in a file to my own standard classes... A lot of surveys I receive contain the same class names and I want to turn each of those into names I prefer. Can anyone provide an example?
I'm calling up the values under the 'Data Fields' tab of wall styles into a worksheet. The values appear to be formated as text. In particular when calling up the Thermal Resistance Field: =('__NNA_Wall_Style_Format'.'Thermal Resistance') I'm unable to preform calculations on the database row without getting the result '#VALUE!'. 1) Is there a way to force the returned value in the worksheet to be formatted as a number? 2) Is there any way to find/modify the '__NNA_Wall_Style_Format'? Andrew N. VW12.5 Designer OSX 10.5
Hi, Trying to create a script within a palette that will let me draw a line with a preset object name defined within the script... Don't know much about Vectorscript, I've tried using 'NameObject' but it doesn't give the line a name in the object info palette under the data tab as I hoped. Procedure CustTool; VAR Name:STRING; Result:BOOLEAN; BEGIN PushAttrs; NameClass('NonPlot'); CallTool(-201); NameObject('testing'); END; Run(CustTool);
