Yes. The linework shows up when I spin the model around in openGL, but not the rendered vp. I have rendered the vp with the display planer objects checked and unchecked, neither produce lines at the base.
I am trying to view 2d lines from landscape and civil as a base to my 3d model and have it render in viewports. I have imported the landscape architects DWG to give their line work by using the shuttle file method. This has been viewport referenced onto one of my design layers with elevation set at the ground plane. I would like for these lines to show up in my 3d camera viewports, but they are not.
Any tips on how to proceed or trouble shoot this. Thanks!
Please please please add viewport functionality to the Visibility tool. When I am setting up a viewport on a sheet, I would love to be able to turn off unwanted classes by clicking on items, and voila, the class is turned off.
Yes, this was a problem for me also. The workaround I found was to create a layer which I call a "wall fix layer", then set the height for the origional wall height. I then create a large extrude or roof plane on that layer to which the wall can then be re-constrained to. Turn off the actual roof layer and re-trim the wall to the wall fix layer. I keep this layer turned off and only turn it on when I want to fix one of my walls. This also works for fixing a wall which has been cut to a ground plane.
