HAUSrucker
52 -
Posts posted by HAUSrucker
hi - who can i draw an arc tangent to two arcs with one command?
thank you
oh - yes - that was the problem - thank you
hi - i need a list of the square meters from different walls - is i take the wall quantity report.
i made a wall with 10m length and 2,5m height -> 25qm - Area (Gross)
now i placed a door with width 1m and height 2m -> 2qm
why i don?t get a Area (net) with 22,903qm???
it should be exactly 23qm!!!
thanks
ok - but i want to get the surface for painter - so i had to subtract the openings from the space surface and i won?t do it by hand!
e.g. allplan subtract all the windows or doors from the space surface
hm - can you give me an examplefile?
i don?t really know what you mean!
thank you
hi - is it possible to create a worksheet which shows the space and the doors which depends to the space?
a worksheet with isn?t a problem - worksheet with doors also - but can i give a door a link to a space?
thank you
markus
i?ve tried to export to allplan 2008 but i lost the space!
also i tried the nemetschek ifc-viewer - walls and doors are perfect but without spaces!
any idea?
thank you
markus
hi - who can i extract the area of the room finish - e.g. the area of the tiling?
thank you
if i export IFC 2x3 there is no space object exported! why?
(2009 sp2)
thank you
ok - that works - but copy and paste e.g. to another level is a problem.
if i copy walls to another level i ve to join by hand :-(
wow - i have to click on every wall?
i know functions from archicad - it makes wall joins by itself!
thank you
hi - which command can i use to join copies of walls automatically?
ahhh - ok - thanks
i found the file Wall Styles Metric.vwx an deleted all in the drawing area and in the resource browser, but there are still the default walls in the menu!
hi - how can i change the color of the fold marks from a border?
thank you
hi
where can i edit the default wall style list?
thank you
Ah - ok
but i can only position the pillar in center, left or right - any other offset is not possible?
if i copy the pillar in a other layer and copy the wall - the insertion don?t work!
is there a function for recalculating insertions or other join-modes?
thank you
how can i change part line style e.g. jamb for more doors?
i select a few doors, but vw changes only the first one!
thanks
hi - newbie question:
where can i switch on a function to break with a column a wall?
thanks
yes - i enter now the height manually by a right click on the dimension - go to edit dimension and click to show elevation - type manually in the height.
thats not very comfortable, but it works - thanks to all
the "5" is not the problem - that is solved - but to query the height might be possible? i hope! i don?t wont to do it by hand!!!
in archicad it works since i can think!
hi - i?m new to vector and i?ve got a big problem with the dimensions.
how can i dimension the height of a window and door like in the picture?
thanks
hi - i?m searching a voronoi (2d) script!
does anybody know such a script or a place where i can found it?
thanks
markus
hi - i m a vw newbie and searching for good tutorials which teach the combination vw and database like filemaker or teach how to make reports for architectural quantity survey.
thanks
Architectural modeling in VW or other software?
in Architecture
Posted
for complex modelling you can use rhino and import/export via fileformat ._xt
