  • Sign in to follow this
    Wall Lines on Doors and Windows
    PVA - Jim
    A common question of Vectorworks users is how to remove the display of wall lines across Door objects in Top/Plan view so that the doors show as an opening.
    There are two common mistakes, the first of which is that you may not be in Top/Plan view. If you are in Top view, you will see the wall lines continue though the door no matter how you modify your visibility settings:
    The second (and more common) is that the Ceiling-Main class is enabled. This class controls the visibility of the wall lines that pass through window and door objects.
    With Ceiling-main off:
    With Ceiling-main on:
    Edited by JimW
      Report Article
    User Feedback
    There are no comments to display.
    Guest
    Add a comment...
      Only 75 emoji are allowed.
