Ken Fisher
Shaders
I prefer to use shaders for brickwork rendering, but those available do not show a British size brick!
Is there any way of editing shaders to change the proportion of the bricks to 215mm x 65mm ?
Unfortunately, there is no control of the separate sizes. You can adjust the length only. You can set the size to 215mm of the shader and this will give you the closest size to what you are looking for.
We are looking at having more flexibility in future releases, however at this time the limits of the shaders do not allow what you are looking for.
If you so desire, you could use the image texture capacity. By using a digital camera you could import the image of British bricks and have a little more control as well as having an accurate representation.
Brian O
Nemetschek North America
Technical Support Specialist
