If you open a new blank file + create a default unstyled Landscape area then immediately delete it + any resources which came with it (a line type?) you have a file with no objects + no resources in the RM. All that remains of the LA are the 'Site-DTM-Modifier' class (which you can delete) + the 'Site-Landscape Area-Spec' class (which you can't.) In order to delete the '-Spec' class you first have to run Purge with 'Special record formats' enabled. After purging the file of this format you are t
