glee Posted January 27, 2001 Share Posted January 27, 2001 I have been having problems w/ the door disappearing on the plan sheets. The door casing and jambs are there but the door and the swing are missing. Whats going on ??? Quote Link to comment
dlstudios Posted January 28, 2001 Share Posted January 28, 2001 Check the visibility of the class "Sills." Door jambs and casings go into the class "Doors-Main" but the swing and door itself go into "Sills" I believe. Quote Link to comment
dlstudios Posted January 28, 2001 Share Posted January 28, 2001 Also, have you had problems with doors and windows resizing themselves for a different wall thickness. If you create and 4 1/2" wall (1/2 drywall on either side of a 2x4 stud), place a door or window in the wall, convert the door or window to a symbol leaving the original instance in place and later edit the symbol (for instance change the casing width) the door will resize itself for a 4" wall, not the 4 1/2" wall in which it was orginally inserted. Nemetschek is aware of the problem and says it will fix it in the next release. Quote Link to comment
