jurgen Posted November 16, 2005 Share Posted November 16, 2005 A View, saved in VW 10.5 is no longer editable. If I open the File in VW 11, it is not even visible in the Views-Menu, any suggestions? Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted November 16, 2005 Vectorworks, Inc Employee Share Posted November 16, 2005 Which version of VW 11 are you using? In 11.0.x, views that had some problem with them (such as a reference to a non-existent layer) were deleted on file read/import. I believe this was changed in 11.5 so the views would be repaired rather than deleted. Note that if they have been deleted, 11.5 won't bring them back; you would need to re-import the file from 10.5. Quote Link to comment
