El Dinyo
Fix 2D Path Plugin Objects (phantom paths returning from past)
Can 2D Path Plugin event based objects please be fixed?  They do not work correctly.  When moving objects, it still seems to have the previous location in memory. When using clipping/adding surfaces to object, it still seems to have the previous path in memory and future adds/clips negates the changes that you made previously to the 2d path.
Vectorworks support states they don't support custom plugins, but this problem is Vectorworks having bugs in their platform.  This was introduced in version 2019.
The only half workaround I have found is the force the object to enter reshape mode.  However, even this does not work all the time and leaves the user in the wrong mode to continue the workflow.
Any help would be appreciated!!
0 answers to this question
