Is there a setting for the 3D Locus visibility when in wireframe ? I've used it before with no problems, but now in any file I open I can not see the Locus points, if I select all then I can see a bounding box around them but not see them. I must of changed a setting accidentally for this to happen & can not find any setting for it.
Thanks for any suggestions!
So this is new. My 3d loci are not showing up and the culprit seems to be Unified View. 3d loci are set to display in wireframe, but do not, until I turn off Unified View. This is new, and I do not like it. Thoughts? I don't recall having this issue before the latest service pack update.
