JHEarcht Posted September 30, 2004 Share Posted September 30, 2004 VW 11.1 on Windows XP I'm trying to import an Adobe Acrobat PDF file which was saved as a bitmap in several formats: TIF; EPS; PICT. Each time I import the image displays as a gray box with an X. The image looks fine in Photoshop. Any ideas will be appreaciated. Thanks, JHE Quote Link to comment
Guest Posted September 30, 2004 Share Posted September 30, 2004 You should only get that with the EPS, not with the other two formats. Turn the preview off when saving it as an EPS/EPSF to avoid the X Quote Link to comment
JHEarcht Posted September 30, 2004 Author Share Posted September 30, 2004 Thanks Katie, The EPS was saved with no preview. Still none of the bitmaps would import. Eventually, I discovered that I could export all PDF images as PNG. VW11.1 imported that file with no problem. So far, PNG is the only bitmap format that doesn't give me a problem in VW11.1. Oh well, back to work. JHE Quote Link to comment
