Heath Posted September 22, 2004 Share Posted September 22, 2004 Is it possible to not show grid lines in viewer. Grid lines are not shown when drawing is saved. Please help. Quote Link to comment
Guest Posted September 22, 2004 Share Posted September 22, 2004 Go to Page>Set Grid Remove the check mark next to Show Grid Lines. Quote Link to comment
Heath Posted September 22, 2004 Author Share Posted September 22, 2004 This option is not available in the viewer program. There is no set grid. Quote Link to comment
Guest Posted September 22, 2004 Share Posted September 22, 2004 Make sure you do not have Show Grid checked in your file prior to saving. You can have show grid checked but not see the grid depending on layer scale, zoom factor, etc. Quote Link to comment
Heath Posted September 22, 2004 Author Share Posted September 22, 2004 I have another problem with viewer 11. When I try to use help I get this error; "an error occurred while opening the help system. Make sure the "VWHelp" directory is in the same directory as the application." I have un-installed viewer 11, re-downloaded and re-installed with the same result. The file "VWHelp Resources" is in the Vectorworks Viewer 11 folder. Any suggestions? Quote Link to comment
Guest Posted September 22, 2004 Share Posted September 22, 2004 Are you using a Mac or PC ? Quote Link to comment
Heath Posted September 22, 2004 Author Share Posted September 22, 2004 Windows 2000 PC Quote Link to comment
