was Posted January 30, 2003 Share Posted January 30, 2003 I want to make quality Acrobat pdf files of VW drawings that have transperant overlays to layers. Using a postscript driver to write the pdf does not work nor does distilling a postscript file (objects below are obscurred by filled polygons). Any suggestions? Quote Link to comment
Guest Posted January 31, 2003 Share Posted January 31, 2003 Adobe Distiller. It's a member of the Adobe family and is the true PDF writer software. Quote Link to comment
was Posted February 4, 2003 Author Share Posted February 4, 2003 We have Adobe Acrobat 5 which includes Distiller 5. But still cant get transparent layers to work. Not with the pdf writer nor by writing directly to pdf or postcript file through a postscript print driver and then distilling Quote Link to comment
Guest Posted February 4, 2003 Share Posted February 4, 2003 Trasparent layers are not supported by post script, which is why you cannot get transparency to go thru. The PDF generates the file via post script. I don't know of a way around printing to PDF with transparent layers. I missed the trasnparent overlay layers comment in the first message. There are other PDF writers out there which you can download off the internet that are more image based rather than true PDF files. I don't know alot about any of those applications. Some research with their creators can help find out if you can write transparency to any of the PDF writers. [ 02-04-2003, 09:56 AM: Message edited by: Katie ] Quote Link to comment
was Posted February 7, 2003 Author Share Posted February 7, 2003 Would be poosible for the image export function to be more refined to allow raster image writing to pdf with high level of control over image size & resolution. When I export an image file, VectorWorks writes a file that covers the whole drawing rather than the print window. This is unsatisfactory as often drawing bases are much larger than the print window and there is alot of editing time required to clip them back. Quote Link to comment
Guest Posted February 7, 2003 Share Posted February 7, 2003 VW 10 has a Marquee select function in the export image file. You can marquee select the portion of the file you wish to export as an image file. Quote Link to comment
