akikohw Posted September 24, 2003 Share Posted September 24, 2003 I've just upgraded from 10.2 to 10.5, and noticed that some of the text blocks, or even just portions of the textblocks, plot as a black background with white text. I typically use a black background to draft, and switch to a white background to plot. The plotter I'm using is an HP 750c plus. I've tried plotting the sheet twice (which would fix the overlapping text problem) to no avail. Any suggestions to fix this? Quote Link to comment
Guest Posted September 24, 2003 Share Posted September 24, 2003 Have you tried plotting with BlackBack ground on? Does this happen on all files or just one in particular? Quote Link to comment
akikohw Posted September 24, 2003 Author Share Posted September 24, 2003 It does the same thing when I plot with the black background on. I have noticed this on files that I created in 10.1.2. I tested small files created in 10.5 which didn't seem to have this problem. Quote Link to comment
