Sam Combs, AIA, NCARB Posted July 28, 2003 Share Posted July 28, 2003 I know that others are having similar problems, i.e., when opening a file and renaming it to begin another set of drawings-the text corrupts. Title Block text, note text, drawing/detail text is in another font, turned at right angles, just generally a mess. Note that on screen the text looks fine. It is just when I print on my printers-HP2600, HP455CA & Kyocera-Mita 1810, that the text comes out corrupted. Anyone know how to fix this and what causes this? Thanks! Mac OS10.2.6 VectorWorks 10.1.2 G4 500mhz Dual Processors 1.5 GB Ram VW 10 on the primary partition in Mac OS 10.2.6-40 GB Total Disk Space: 120 GB Quote Link to comment
Sam Combs, AIA, NCARB Posted July 28, 2003 Author Share Posted July 28, 2003 I just found out a way to solve this problem. When you go to print, go to VectorWorks preferences, check "Disable driver text rotation". This solves the problem. I still don't know what causes this-does anyone know? Quote Link to comment
Guest Posted July 28, 2003 Share Posted July 28, 2003 If the file has the text displayed flipped when you OPEN the file, go to File>Preferences, VW Preferences. Click on the Display tab and check mark "Adjust Flipped Text". If the text is flipped when PRINTING, check mark disable driver text rotation (mac only). Quote Link to comment
