AndyM Posted December 20, 2002 Share Posted December 20, 2002 I am using an open type font for drafting. This has worked fine for quite some time, however, this week everytine I open a drawing with this font it is replaced with Arial. I can change the font back to the one I want, and I can use the font at will and it works fine. But if I close and re-open the drawing it is again replaced with Arial. I do not get a font mapping screen when I open it and it does not show up in the "edit font mapping" screen. Any ideas? Quote Link to comment
Guest Posted December 23, 2002 Share Posted December 23, 2002 Andy is this a file that was created on a mac at any point, or was it all done on a PC? Quote Link to comment
Guest Posted December 23, 2002 Share Posted December 23, 2002 Did you add or remove fonts from the font folder? That can cause problems. Past Font Problem on Windows Quote Link to comment
AndyM Posted December 24, 2002 Author Share Posted December 24, 2002 Yes, it has been worked on on both mac and PC, and both have the OTF installed. I have not checked to see if the problem is present on the Mac but I will. I also do a a bit of adding and removing fonts. However, the font in question has been on my system throughout the life of this document. Thanks for the help on this. I will try removing and re-installing the font. [ 12-23-2002, 10:37 PM: Message edited by: AndyM ] Quote Link to comment
