Dillon Posted May 28, 2014 Share Posted May 28, 2014 My renders using the Renderworks backgrounds (Eg. HDRI domes-- mostly sunny day) come out looking blue. I think this is because the horizon line of the dome doesn't align with the horizon that I've set using the Renderworks for my perspective. For example a bird's eye view has the horizon way at the top of the image, not in the center. Does anyone else have this problem? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 28, 2014 Vectorworks, Inc Employee Share Posted May 28, 2014 (edited) I do not believe there is a way to tilt the HDRI background, it will always align with the document, so if you looked at an object rendered in a Front view, the bottom 50% would be the ground and the top 50% would be the sky. However, For that HDRI background, the ground is quite blue, unless I am misunderstanding your question. I have attached 3 examples here, one not tilted, one tilted up and one tilted down: [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=10695&filename=HDRI%20BG%20Sunny%20Day%20-%20No%20tilt.PNG[/img] [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=10697&filename=HDRI%20BG%20Sunny%20Day%20-%20Tilted%20Up.PNG[/img] [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=10696&filename=HDRI%20BG%20Sunny%20Day%20-%20Tilted%20Down.PNG[/img] Is this what you are seeing? Or is the sky actually flipping and showing on the ground? Edited May 28, 2014 by JimW Quote Link to comment
