Damian O'Neill Posted March 28, 2014 Share Posted March 28, 2014 Hi, I am new to this forum and have my first question. I extrude a rectangle and using the clip cube, I cut the 3D rectangle and then render using OpenGL. I would expect the part that is in section to show as solid, but it is rendering as if it is hollow ? Am I doing something wrong Thank you Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 28, 2014 Vectorworks, Inc Employee Share Posted March 28, 2014 Currently the clip cube will just remove the face from 3D geometry, unlike Section Viewports which add a controllable clip plane on areas of 3D geometry the section line bisects. You can not currently do this with the Clip Cube alone (Though there is a request to add this functionality in the works) but you can create a section viewport from the clip cube that might get you what you're expecting: Quote Link to comment
