W Wilkerson Posted September 6, 2013 Share Posted September 6, 2013 (edited) Attached is a file highlighting my issues. In the past, the field w/in the blue box of the label legend created with the class "Setup Notes" never showed up when the label legend was in use on a fixture. In this instance, "User Field 2" and "User Field 3" and are showing up. I know that I can deselect these fields from the label legend manager, but I am curious why it now shows up where in prior versions of VW it did not. What do the red versus blue boxes mean in the label legend symbols? Also, the bottom fixture has data in all of the fields that have a container: Dimmer, User 1, User 3. If one turns off the visibility for those classes, the bottom fixtures' data in their respective containers disappears, but the top fixtures' data-less boxes stay visible. Why are my data-less containers staying visible when their respective class is turned off? Thank You, weston Edited September 6, 2013 by W Wilkerson Quote Link to comment
