carpalmer
Hidden Lines won't work VW13
Have been working on some interior renderings using RW and applying hidden line to foreground. As drawing got more advanced VW13 refused to render lines, got blank VP, and "out of memory" message. Tried rendering hidden lines only, also rendering in design layer, but to no avail...
then exported to VW12 and it rendered hidden lines like a charm! So pls look into it, also had similar issue with "clipping surface" command for grille work pattern: VW13 failed to do it properly (leaving some unclipped areas), exported to VW12 and it worked fine! Pls address both items since these are fundamental assets to the program...
many thx
Carpalmer
