MBtheTD Posted March 5, 2012 Share Posted March 5, 2012 I'm having an issue with a filleted extrude in a section viewport. I've filleted the leading edges of an extrude, and in top/plan view, it's dimensions are fine. In the section view port, it's size is different. If I remove the fillet from the extrude, everything is hunky-dory. I've tried redrawing the extruded shape as a solid, but the same problem; the dimension is smaller when filleted and fine if I remove the fillet. Is this a bug with the program, or am I missing something? Michael VW 2012 SP 2 Windows 7 Enterprise Intel Core 2 Duo CPU E7500 @ 2.93 GHz 4 GB RAM Quote Link to comment
