Jack_1983 0 Posted July 29, 2011 Hi all, I'm stuck with a simple problem (or so I think), but I can't seem to find a solution. By following the Sample projects which come with the SDK, I was able to set-up a menu chunk with 4 menu items in it. Now I would like to disable a single item at runtime, but I can't understand how to achieve this. The menu plug-in I defined is practically the same as the one in the "VWUI Dialog Samples" project. The SDK manual simply states that some particular events (by the way, the kMenuCheckHilite action is what I should check, I think) are dispatched by VW by calling the main plugin function (plugin_main) but this is not what is happening. I also tried to override the OnDefaultEvent function of the Event Sink class, but that is simply never called. Anyone of you can point me to the right direction? Thanks in advance Jack Quote Share this post Link to post
