When using the Hardworks tool in 2D and you select spaced joint in the Joint pattern box. The Spaced joints are at 90 degrees to each of the border lines, this depicts a soldier course or brick edge really well. However, when you put a Soldier Course or Brick Edge texture in the 3D options ?Border Texture. The joints are the same angle all through the border (not at 90 degrees to border). To be able to make these joints perpendicular to the edge would be great as so many hardscapes are bordered by bricks or tiles.
Hardant
0 answers to this question
