Ronald Prochot
Measuring in 3D space in MiniCAD 7.03
I am finding that the tape measure only gives accurate measurements in orthographic projection: front, rear, plan, side and bottom views, but gives incorrect readings in isometric. Is there a way the tape measure can be used to measure the modelin isometric, in order to then work accurately with these dimensions in the active layers comprising the model? At the moment I can only measure the model in orthographic projection in order to get any meaningfull dimensions from the model. (For instance Form-Z allows one to measure a model in S-D space.)
