MacG3Freak Posted July 1, 2009 Share Posted July 1, 2009 Hey everyone, I can't get the wall framer to work properly. I can frame the whole wall, but the framer puts the studs in the exact center of the wall. This would be fine except the studs in the walls I'm using are offset slightly to the inside of the building. When I try to select just the wall structure class (which is what I have my studs classed to in the wall attributes) the framer tells me that no walls have been framed because there are no walls to frame on the selected layers/classes. I'm so frustrated and I'm up against the wall here. Any help would be greatly appreciated. Thanks! -Warren In the picture the green lines are obviously where the framing members are being put, the red lines are where I need them. Quote Link to comment
