BruceT Posted January 22, 2009 Share Posted January 22, 2009 (edited) I just upgraded to 2009 and I have a serious problem with extrudes. In 12.5 the extrude would extrude from the working plane if you were in working plane mode in working plane mode and from the ground plane if you were in ground plane mode. Now, no matter what I do, extrudes alway extrude from the ground plane. Is there a new option in 2009 which needs to be set to allow extrudes from the working plane or is this a bug? If it is a bug I will have to go back to 12.5 to do my modeling. I just noticed that this only seems to happen if the working plane is parallel to the ground plane. If I rotate the working plane to perpendicular to the ground plane then the extrudes grow from the working plane. Edited January 22, 2009 by BruceT Quote Link to comment
