jss273nyc Posted January 5, 2009 Share Posted January 5, 2009 I have a problem with extruding along a nurbs path. The object I'm sweeping is a half of a tube (I'm trying to model a slide). When I extrude along this 3-D nurbs path, the object rotates itself along the path so that at the end, the extruded surface is rotated 90 degrees from its original position. Is there away to prevent this rotation so that the orientation of the swept object is the same at the beginning as it is at the end? Quote Link to comment
