grandcasita Posted October 2, 2008 Share Posted October 2, 2008 Has anyone else experienced a failure to export solids as ACIS objects either using the Export As... Export SAT or Export As... DXF? I have a rather time critical model which exported fine in VW2008, but fails by all methods in 2009. A DWG export is read by ACAD, but then exports incorrectly from there. Simple objects seem OK, but once I subtract or add solids, nothing goes across, even the simplest extrudes. Quote Link to comment
