Dieter @ DWorks Posted March 31, 2008 Share Posted March 31, 2008 What I want is to be able to control the order of the wall components. So we can control wich component is at the back and wich is in front. Why? If you use wall components with different colors you'll want one color of two next to each other wall components to be on top when they are both shown. when the class of the component is put out, you'll need to show the line of the other component, which is a different color, and that's not posible now! Quote Link to comment
maarten. Posted March 31, 2008 Share Posted March 31, 2008 Indeed! Also, because the lines are on top of each other and both showed, you can get some weird things like this: Quote Link to comment
RubenH Posted March 31, 2008 Share Posted March 31, 2008 (edited) Now you can use "none" if you don't want to show the left or right line in a defined component in "Edit wall attributes". Anyway the idea of send to back componets or front is interesting and one good complement! Edited March 31, 2008 by Mr. Gog Quote Link to comment
Dieter @ DWorks Posted March 31, 2008 Author Share Posted March 31, 2008 Now you can use "none" if you don't want to show the left or right line in a defined component in "Edit wall attributes". You can do that, but what if you want to only show that component in a viewport? Then it will have no boundary line. Quote Link to comment
