raidfibre
Shell solid fails miserably
I am trying to draw a solid that will be the model for a thermo-formed plastic part. I have created a solid 3d shape by extruding a 3d poly to the required depth. I then created two simple 3d polygons which I extruded and subtracted from the main solid.
I then try to shell the solid and it fails with the frustratingly ambiguous error message "shell solid failed" How should I create a shell if VW won't do it, and won't tell me what's wrong?
I have no idea why it failed.
I didn't know one could extrude 3D polys--you sure that's what you are doing?
Yes, it's a closed "3d polygon" drawn on the working plane and then extruded.
I make a workaround that hopefully will be ok. I think the problem is when you have too many planes intersecting at one point (I had 4). The algorithm just can't figure out what to do.
I changed my geometry a bit and it worked.
raidfibre,
If you used 2D polygons instead of 3D polygons, does it make any difference?
I've done a lot of thermoforming mold design, and have mostly used 2D polygons or rectangles for the extruded profiles.
