The way these commands work makes the result not usefull.
These commands draws polygons for every object that is selected, even if they will not be seen. Thereby, there are too many polygons in the group. It's very hard to handle if you want to edit the result. Also objects which should be 1 polygon is divided into smaller polygons wich is very annoying to edit.
So my wish is to rework these commands so that only the polygons that will be seen are drawn and are drawn as 1 polygon.
Right now I need to convert to lines and then fill up the lines with polygons, but the bucket mode of the polyline tool is way too slow. It can take op to 1 minute to generate a polygon.
Dieter @ DWorks
0 answers to this question
