B.Balemi Posted April 13, 2003 Share Posted April 13, 2003 Gidday Team this is my first post.I have been watching for some time with interest. In 9.5 (have 10 but to busy to make jump will do in a week) Hope not a dumb Question. Can you have editable parameters in a linear plugin type .Keep getting error about wrong type parameter.Have I read the language Guide correctly ,copied there exact example and got the same error. They state that this is possible. Im sure the answer is obvious to you big brainers out there. Cheers -------------------------------------------------------------------------------- Quote Link to comment
Fuge Posted April 17, 2003 Share Posted April 17, 2003 Yes you can. If your getting errors check some of the following: Make sure the parameter fields have valid starting values and none are left blank. Make sure the variable types your declaring in your script match the parameter type. Your problem is something like that. Also to maybe help you determine the problem. Add {$DEBUG} above Procedure in your script. Dave Quote Link to comment
Guest Posted May 23, 2003 Share Posted May 23, 2003 I would need more details in order to figure out what is wrong. What is the exact wording of the error message you get? Which example from the language guide are you referring to? Jeff Quote Link to comment
