Sebastian Giese Posted March 26, 2024 Share Posted March 26, 2024 (edited) Hi all, i created a network to assign objects to classes, fairly simple. I used the Node "Get Record Field" to get information about the objects. As a Marionette network it works like a charm, but when i save it as a script and execute the script, i get the following errors: and a lot more in the same style. I inspected the given lines in the script and found around the indicated lines following code lines in the node "get Record Field": This looks like this node is not correctly working and the developer should talk to Mark?? 🙂 The node is #Modified by MFarrell May 2017 Attached the script and the network. Cad anyone help with the node or the script? Or anyone have a newer version of the Get Record Field Node? Ooooor anyone have a different idea? NM_Klassensortierer.vwx Klassensortierer.zip Edited March 26, 2024 by Sebastian Giese Quote Link to comment
Marionette Maven Marissa Farrell Posted June 5, 2024 Marionette Maven Share Posted June 5, 2024 @Sebastian Giese First, that comment in the code can be disregarded, it seems that the initial writer of that node just wanted to check on syntax, but there isn't an error there. It works appropriately. Second, the error you're receiving is that the script you exported isn't aware of what object you're trying to act upon. I'm unable to get your network to run when I run it in the file you've provided. I'm given an error: Quote Link to comment
