Add Grade Def to Document settings: Units
Carol Reznor
Add Grade definition to Document settings
  1. 1. Add Grade definition (percent, rise/run ratio, or angle) to Document settings
    • yes
      0
    • no
      0
Hi
This is about the setting for Grade Def: Select the type of display for the slope (percent, rise/run ratio, or angle)
WISH
For consistency throughout the document/project It would be nice if the way the grade is defined (percent, rise/run ratio, or angle) can be set in File > Document Settings: Units, Scale and Grids.
As a consequence: In the OIP of the object using 'the display for the slope' the default option then could be 'Document Units'.
This eliminates the need to set this for every object separately.
Also take into account linking the setting of Profiles, Longitudinal Profile, or Transverse Profiles.
Thank you
0 answers to this question
There have been no answers to this question yet
