Hello Community! Our community board will be offline for maintenance as we perform an upgrade from June 8th at 8:30 am ET until June 9th. We appreciate your patience and understanding during this time.
- 0
Carol Reznor
Hi
This is about the setting for Grade Def: Select the type of display for the slope (percent, rise/run ratio, or angle)
WISH
For consistency throughout the document/project It would be nice if the way the grade is defined (percent, rise/run ratio, or angle) can be set in File > Document Settings: Units, Scale and Grids.
As a consequence: In the OIP of the object using 'the display for the slope' the default option then could be 'Document Units'.
This eliminates the need to set this for every object separately.
Also take into account linking the setting of Profiles, Longitudinal Profile, or Transverse Profiles.
Thank you
0 answers to this question
