I have just released a plugin to create catenary curves.
From Wikipedia:
Catenary is the curve that an idealized hanging chain or cable assumes under its own weight when supported only at its ends in a uniform gravitational field.
It is essentially a "line object" plugin: click and drag to get the initial couple of end points on the XY plane.
Customizable parameters:
  • Independent Z for both ends.
  • Direction [downward (chain) or upward(arch)].
  • By length or by sag methods: you can establish the length of the chain or the chain lowest (or highest) point.
  • Buttons to extract a 3D polygon or a 2D polygon out of the PIO.
More info on my site page: Catenary Curve for Vectorworks®image.jpeg.475052565f760b4e944a231bb2859658.jpegScreenshot2024-02-07alle19_26_21.png.2218015e0f77062a56325a2023589c19.png
  • Like 2
  • 2 weeks later...
From Wikipedia:
I could have used this so many times in the past.  Will be downloading.  Thank you!
