How to modify the Z value decimal places of 3D loci
JAMZ21
Often we receive surveys with 2D text elevations in meters at varying decimal points. However, the survey and linework are drawn in millimeters.
When I use the convert text to Loci networks on the forum, the resulting points are not accurate, because of the change in units.
Does anyone know a simple way to select all 3D loci and change the decimal points of the Z value?
Alternatively, is it easier to multiply the 2D texts first and then run the text-to-point networks?
I'm sure it's an easy fix.
thanks
Hello,
changing the z-value of a 3d locus can be done with Marionette. Unfortunately i am not familiar with the "Text to loci" network that you are referring to, so i dont know if my example network is a good solution, but maybe you can point me in the right direction.
This is how such a Marionette could look like:
The Marionette works like this:
  • At first it searches for all the 3D loci with the "Objs by Crit" node
  • Then it gets the location of each found locus and finds its x, y and z values
  • Then it does something to the z value (in this case i divided the z value by 10)
  • After that the Network puts the coordinate values back together in the "Point 3D" node
  • And finally sets the coordinates of the 3D locus to the new values
Regards,
Letti
