Kent Goetz
class visibility in sheets
I wish that when I create a new class that it would default to "visible" instead of "invisible" in all my saved sheets. It is a real nussance to edit all the sheets in order to see objects assigned to the new class.
1 answer to this question
When you are using sheets, unless that class or layer is added to the sheet, it will appear invisible.
A sheet is another way to organize a set of drawings. When you make changes to the layers and classes list, you have to edit the sheet to do that.
I can add this request to the wish list, however I do not know how it will go over. You would then be added classes and layers to your sheets without saving them, but esentially saving them.
I'll add it for you none the less
