Alex Noel Posted May 15 Share Posted May 15 I'm having trouble using the path extrude node in my marionette networks. It seems that whenever I use it, the extruded object created ends up in a totally different place than where the path was. Can anyone help explain that behavior? Mostly, I'm trying to create square metal tubing that follows a path (either nurbs or a polygon) using the control geometry node. As a note- all my profile objects are centered on the origin. Some are created within the marionette network, and some are existing objects already in the document. Thanks Quote Link to comment
