AlHanson Posted February 23, 2023 Share Posted February 23, 2023 I'm struggling with adding a resource popup widget to my OIP. I can make a resource popup work with using a kWidgetButtonResourcePopup (105) and then calling vs.vsoButtonGetResource when the widget button is pressed just fine, but it sure isn't as pretty as the actual resource popup. 😁 Whenever I use kWidgetResourcePopup (107) I'm adding the popup to my OIP just fine, however there's no data there and it's just greyed out. Clicking on it doesn't cause the resource pop up to display like with the button, nor does it do anything in terms of flagging events like the kWidgetButtonResourcePopup approach. I've enabled kObjXPropSupportResourcePopup (53) via vs.SetObjPropVS during kObjOnInitXProperties. I've tried using vs.vsoWidgetPopupAdd(N) to feed random data to it which doesn't seem to be the way to go about this. Doesn't seem to be a way to link it to a resource list that's been built...? What am I overlooking here to make this work? Quote Link to comment
