Guest Posted February 20, 2003 Share Posted February 20, 2003 Is everything on the same layer (active layer) when rendering? Did you happen to duplicate the object on top of itself? If you have a duplicate poly on top of itself, it won't render - it will remain in wireframe. If the above isn't an issue with this file, please send the file to me and I'll take a look at the file. tech@nemetschek.net?subject=ATTN:Katie Quote Link to comment
0 Chris Hunt Posted February 21, 2003 Author Share Posted February 21, 2003 I've just started using 3D to construct a model of a house. All going well until I've edited one wing by changing it to another solid addition and now that wing won't display with hidden line removal. The rest of the model will but not that one wing. Anyone any ideas what I may have done wrong? Thanks, Chris Quote Link to comment
0 Chris Hunt Posted February 21, 2003 Author Share Posted February 21, 2003 Thanks for the thoughts Katie. It wasn't that though. I found I had the "Fill" for the object set to "None" in the Object Info pallette. When I set it to "Solid" it worked. Do you know any good books or tutorials on 3D modelling for Architects? Thanks, Chris Quote Link to comment
2 answers to this question
