With text colour set at use class attributes if you then change the pen colour of the class the text colour is not updated. on trying to manually alter the colour of the text vw crashes.
also colour change associated to classes doesn't work through the referencing of a file.
with vw9 it was necessary when referencing to edit all classes without making any changes and then ok-ing. this although annoying was a quick fix for the problem. however this no longer works with vw10
n b
1 answer to this question
