n b
13 -
Never
Reputation
0 NeutralPersonal Information
Occupation
architect
Location
uk
problems with attributes between files
n b replied to n b's question in Wishlist - Feature and Content Requests
quote: Originally posted by Katie: Do you have that class created in the new file you are pasting to? What type of objects are you copying and pasting? Are the 2d or 3d ? no i don't have the classes already created in the class. copying all types of objects both 2d and 3d. though having said that i just tried to copy into file where the classes existed and it changed the class of some of the elements to none. this is not helpfull wastes lots of time. i still fail to see why your customers are forced to test your application. i appreciate this is not your fault personally but i'm wasting a considerable amount of time correcting elements of the application which used to function. -
quote: Originally posted by Katie: The object has to be a memeber of a class where that class name does not exist in the document to where you are pasting the object to, AND the class attributes for that class need to have "Use at Creation" checkmarked. With this criteria, it works fine. the use at creation was checked. however although i can now get the line weights and colours to transfer any fills revert to none -
also if copying and pasting between files the attributes are lost -
n b posted a question in Wishlist - Feature and Content Requests
Previously if an object was copied from a file and pasted into another file its attributes were copied with it, if the class did not already exist. Also the class was created with the attributes. With v10.0.0 v10.0.1 and v10.1 this is no longer the case. The attributes are not carried into the file. -
everything is starting to fall apart
i've been working on vw 10.0.1 on a pc 1G MHz 512Mb RAM running windows XP. first problem extremely slow refresh times. I only really appreciated how slow when i went back to using VW v9 Problems with attributes not referencing through and when trying to change the original file attributes associated with class this made vw crash. random problems. eg. anchor points didn't work properly. gave up. went back to vw9 -
let me know when vw10 works properly
i wish software houses would stop releasing software which is obviously not ready for the market. i liked a lot of the changes with vw10. unfortunately the program has become very slow and there are too many problems many of them coming and going without any pattern. i will not waste any more of my time on this. i'm looking forward to a revamped version of vectorworks 10. -
quote: Originally posted by Katie: Check the control point/insertion option in the OIP. There is a grid of 9 radio buttons. If you have the center selected, the rectangle, or any object, will resize evenly on both sides of the control point. If you have the upper left hand radio checked, then that point will sit still and the rectangle will move to the right when changing the x values. If you have the upper right radio checked, the rectangle will move to the left while keeping that point still. funnily enough i've been using minicad and now vectorworks for the last 9 years and i have in that time learnt a little of how to operate the application. it was a problem with the software not the operator. i was using the top left radio button and the object reacted as if i was using the centre radio button. this is purely academic as i have put vw10 back in its box. conclusion. i wish software houses would stop releasing software which is obviously not ready for the market. i liked a lot of the changes. unfortunately the program has become very slow and there are too many problems many of them coming and going without any pattern -
within a symbol. editing a rectangle. the top left anchor is selected. when i increase the y value the rectangle grows as if the middle anchor had been selected. why don't i trust vectorworks anymore. -
offsetting within group causing runtime crash
working on a polygon within a group within a group runtime crash. either VW10 is still incompatibily with XP OS or it is absolutely full of bugs. either way it is taking longer and longer for me to get any work out. and i am becoming less and less satisfied with VW10 -
text colour set at use class attributes problems
With text colour set at use class attributes if you then change the pen colour of the class the text colour is not updated. on trying to manually alter the colour of the text vw crashes. also colour change associated to classes doesn't work through the referencing of a file. with vw9 it was necessary when referencing to edit all classes without making any changes and then ok-ing. this although annoying was a quick fix for the problem. however this no longer works with vw10 -
Problems with vw10 chrashing
doesn't happen all the time in the same situation. i'm not able to work out what triggers it but it still occurs with only one file open. -
n b joined the community
referencing files losing class info VW10
we use reference files as a method for printing and archiving issued drawings. one main file is referenced into a series of different file one for each issued drawing. this enables us to work with coloured links in the main drawing and print with black lines for the issued drawings (whilst maintaining coloured fills) However VW 10 does not carry the class infomation across in the first place. i do not want to have to waste my time going through and re applying the class information each time i reference in a file. It worked in v8 and v9 why has it suddenly droppped out -
when changing an objects attributes from the class defined NONE to SOLID, the default colour is grey not the classes default solid colour (eg white). upon trying to change the object attribute the program chrashes a runtime error. currently running XP professional on a 1 gig processor with 512mMb RAM. Only outlook in the back ground few system applications.
