Chris Manus Posted December 15, 2002 Share Posted December 15, 2002 Greetings Cut 3d sections are grouped it is easy to ungroup,Change glass visibility select top view and pick 3D polys and change line weights Regards Quote Link to comment
0 eldnvn Posted December 16, 2002 Author Share Posted December 16, 2002 Hello, It is agreed in architectural designs that when 3D section cut is applied to a model the cut part is designed with a thicker line. When applying this action in VW Architect the lines remain in the same thickness. I can live with that peacefully and fix that manually but the new created layer containing the cut part is locked and not editable so it's impossible,is there a way to unlock it somehow and apply changes? Thanks in advance i'm a new VW user(arch student),using ARCHITECT v. 10.0.1 in Jaguar. Quote Link to comment
0 Alexandre Villares Posted December 17, 2002 Share Posted December 17, 2002 Another nice trick is to make a 2D section cut, make it thick, ungroup it, convert it to 3D polys and plug it on your 3D section. Quote Link to comment
0 Guest Posted December 17, 2002 Share Posted December 17, 2002 Unlock is under the Edit menu. Quote Link to comment
Chris Manus
Greetings
Regards
3 answers to this question
