Rory Posted December 9, 2004 Share Posted December 9, 2004 after installing the plugin vectorworks crashes at the end of the export. It exports but then the little clock spins forever and nothing happens, and the file it creates cannot be read. Do you have any suggestions? I have reinstalled the plugin once and restarted to no effect. (I am using Vectorworks 10.1 + Cinema 4d r9, the plugin is r2) Quote Link to comment
Guest Posted December 9, 2004 Share Posted December 9, 2004 You should contact C4D regarding this problem if no other solution is provided by other users. They support the plugin. Quote Link to comment
G_Hannigan Posted December 9, 2004 Share Posted December 9, 2004 Are you using a Mac? I'm using VW 10.5 + C4D r9 on a PC. So far the r2 export is working fine for me. If you had the first export release, did you remove the earlier plugs (r1) from from your VW Plugin folder? Quote Link to comment
