Tracie Wueller
    8
Everything posted by Tracie Wueller
  1. I have a set of NURBS curves that represent curbs in a parking lot, and I am trying to change the line color in a 3d viewport. The color change shows up fine in 2d plan view, but when I switch to any 3d view, they revert back to black. I've already checked that "Black and White Only" is unchecked. Any suggestions?? Thank you!!
  2. Hello, Does anyone know if there is a way to make dimensions come in on a different class than "Dimension", and various other plug-ins on classes other than the automatic ones? (Door, Furniture, Plumbing, Etc.) I hope that I am asking this in a way that makes sense... Thank you!
  3. I've double checked the classes/layers and they are the same for both objects. I've also tried duplicating the one that does show, as well as inserting a new symbol from the Resource Browser. None of that seems to work. Thanks for the suggestions, though.
  4. I am having a frustrating little problem... I am referencing in a design layer viewport of an external reference that has one wall with 2 identical symbols placed within it. For some reason, only one of those symbols will show up in the file into which it is referenced. In the external reference file, both symbols show up; also if I double click in the design layer viewport to edit the referenced file, both symbols show up. The same problem occurs if I switch the symbols to plug-in objects, as well. Any thoughts? Thanks in advance!!
  5. Hello, I am a newbie at this, and I am sure it is a pretty obvious question, but I can't seem to figure it out and am having no luck finding anything in "help". I have a floor plan that I have added room names to using the Space Tool. The "Add to Schedule" box is checked. How do I then generate a worksheet with these room names/numbers? Thanks in advance!
  6. I'm trying to draw a wall in plan view that lines up with another wall that is already drawn. When I click to complete the wall, it extends off into infinity aligning with the first wall. Does anyone know what I might be doing wrong here? Thanks!
  7. Whenever I use Hidden Line Render Mode, VectorWorks seems to drop some of the lines that should show up at the intersection of some planes. Does anyone know what I might be doing wrong here? Thanks!
