starling75
287 -
Posts posted by starling75
L join + 2x Tjoin
Beware of dwg import settings viz attached file..
It would be nice to have 3D shrub in VWA, along with the 3D maple tree that comes standard.
Context dependent section could be the solution ...
Another option, thanks. What I did in the end: moved the section line
that was smart solution
That is one option, except I don't want to show staggered lines as my section references. And there's also a bug that causes this:
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=170132
I guess I could wait for a bug fix. And I guess I could draw a separate section marker on my key plan, but that's not very BIM.
Or you can choose - separate cross sections + use attributes of original objects and try to fiddle with classes to make section through trees less visible ...
What about this ...
My version has RW so it's all good. It looks good unless you zoom in on an object, then the render quality suffers.
Depends on your design layer scale and dpi resolution in render bitmap options ...
I would like to crop an area to render for quick analysis, rather than rendering the whole drawing.
render bitmap
For some reason I had it in my mind that we could rotate a hatch locally within a polygon. This is incorrect, right?
?? (not sure, whether you ask for this ..)
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=157296#Post157296
Easy presentation of any data type within the file ...
I had related idea few months ago...
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=31990&Number=157302#Post157302
I have experienced numerous "unexpected" (DUH!) crashes in 2012, all seemingly when using Open GL and sometimes Open GL Flyovers... In my case I suspect it is video card related, but so far I can't pin it down. It is true that VW's 2012 uses the video card much more than previous versions. My card has 512mb, and I wish it had about 4 times that much... Ah, maybe my next machine...
You can't buy better card and replace the old one?
I couldn't see any evidence that they do social housing, on tight urban sites, and derive all their production information from a single model.
You can ask them what and how they do (info@wielarets.nl )
I was only looking for some larger projects ...
Does anyone here extolling the value of working in 3D in VW work in other than a 1-2 person practice? Amongst those do any work on dense urban social housing projects under Design and Build contracts?
Good question. I tried to google:
This is a very recent project and non of it is PIOs, basically it is done as you would in SU. (It took me 2 days, it wouldn't have if I had set it up with stories, walls, roofs windows etc......too tedious and specific.)
No walls? No windows?
I mean that in my experience in most projects only 2D info is (still) generally required (even at large firms) and that 3D info is an extra that most can offer because it is part of modern CAD programs, it is appreciated, even expected but rarely demanded.
Well, yes. That's true...
But I use VW 3d/BIM capabilities (and SU fast modelling capabilities) for my own - architect/designer needs.
Fast feedback, better control, 2d viewports reflect changes in the model .. I just like it!
Btw 2D part of VW is far better drafting program than Draftsight..
But it does.
Create a viewport and put it in an Elevation view.
Select the Viewport
Use the Create Section Viewport command to draw the section line you want.
You now have a section viewport showing a horizontal section.
I stand corrected........
I discovered this function 1 year ago... It was "Duh!" moment
There is very .. very usefull "Duh!" thread on Sketchucation forum. Actually, we could have another one for VW.. (sorry for offtopic)
http://forums.sketchucation.com/viewtopic.php?f=15&t=17315&start=0
Perhaps it is when 3D and 2D are always required however that is generally not the case.
Sorry, I don't get it. What do you mean?
I assure you that VW is faster than SU + DS combination.
Elevation and section viewports are very good even with some necessary 2D fixing .. Definitely better and faster than drafting everything in 2D.
But you have to use it. The way of thinking is different and one has to learn and adopt it.
We don't. As I've said above we use a 2D workflow. We draw plans, sections and elevations separately in 2D.
And have you tried to manage at least one complete project in 3D? I don't think VW "light" BIM is THAT bad.
DWorks looks to use VW 3D parametric capabilities pretty intensively...
It is possible, that in the near future the concept of exchanging data via universal or proprietary files will be obsolete ...
http://beyondplm.com/2011/07/01/my-experience-with-dassault-v6-plm-cloud-on-amazon/
Personally ... I think, that whole BIM marvel must one day reach its climax.
Parametric tools mimic real objects and there is no need to make them better than reality.
You can improve apps speed, interoperability, data sharing, GUI etc but virtual window will be always only symbolic representation of the real one.
Revit or any other app can't escape out of this reference frame.
vw doesn't have to be blazingly fast in the implementation of parametrics but they should do it consistently, with minimum bugs and with big portion of original ingenuity.
This whole run on BIM will softly land on flat part of the saturation curve of parametric functionality.
Just do it right
make it perfect and real ..
(original: http://youtu.be/S5SkI8zmFNw)
Is Vectorworks EVER going to get wall clean-up right?
in General Discussion
Posted
Indeed it wasn't cleaned up, but it was my fault ...
Now it's ok.
