416 -
Posts posted by J Lucas
You could move the door away from the wall, that would pull the wall with it.
Don't know. But once you know it happens, it seems easy enough to avoid, though clearly it would be better if it did not have this unexpected quirk.
I any input from those in the know?
Bill,
I just tried "constrain distance" on a door to a wall. Clicked on the door then the wall 90deg to wall that the door is in. Constraint appeared and held when I moved the door or the wall. Could edit or delete using "edit constraints". The one thing I noticed is if you move the wall farther towards the door than the constraint, the constraint is lost, ie. if you move the constrained wall over the door.
"A lot of times, people don't know what they want until you show it to them."
-Steve Jobs
Try pdf995 printer driver to print to file(s) for printing.
Himanshu,
IFC is Industry Foundation Classes. See here. .
Vectorworks Architect or Designer can be ordered with Renderworks, an integrated rendering program. There is no direct structural calculation or energy modeling program integration.
I size structural members in an appropriate structural calculation program and model them in 3D in Vectorworks. This 3D model is the basis for producing construction drawings and details. See the BIM project examples on this website here .
Himanshu,
At the left click on Written Manuals. There are manuals for 2009 & 2010. This is the same publisher with the link to Amazon, above.
I do not know Rivit, but I do know that Vectorworks Architect w/ Renderworks 2010 is a very powerful and flexible 3D modeling, rendering, and drafting tool. I use it just about every day and, although occasionally frustrated, I have been able to use it to efficiently and effectively design, model, render, and document everything I have dreamed up so far. Also the tech service is very helpful and responsive.
I have used both, and both fail at modeling even the simplest and most common handrail transitions. Might as well not have the handrail/guardrail components. The stair tools themselves are both very useful, however.
Christiaan, I was inclined to take your first comment in good faith and at face value, though I suspected it could be sarcastic (based on your previous posts). Having visited the site you reference, I see that your intent was sarcasm. Was there any constructive result you were hoping for here?
I am very attached to my Logitech TrackMan Wheel. Based on the Logitech site it looks like it I can get the right driver for Windows 7 64-bit.
I thought I would give it a shot.
My experience confirms what Royce states.
After reading a bunch of reviews on processors, cores, hypertheading, etc. here is what I ordered:
Micro Express Computers: MicroFlex 95A
Mid Tower Black ATX Case
Gigabyte GA-P55-UD3R
Intel Core i5 750 (2.66GHz 8M Cache)
8192MB (8GB) DDR3 Memory 1333MHZ
500GB Serial ATA 7200RPM 16MB Cache
25 in 1 card reader supports CF/MD/SM/SD/MINI SD//MMC/MS/XD (No Floppy)
20X Dual Layer (8.5GB)Multi Format DVD Burner
On Board 10/100/1000 Network Card
Microsoft Internet Keyboard and Optical Mouse
High Definition Audio subsystem
Nvidia GeForce 9600 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready
Microsoft Windows 7 Pro 64-bit (includes XP Mode)
For $1300. I saved with the i5 (supposed to have similar performance to i7, except for multi-threading) and went for more memory and a more powerful graphics card.
What "group" is this discussion in? The link does not work unless you are already signed up for this group.
I thought it meant "Perfectly Corrugated".
Thanks again everyone for your comments. When I started this thread I tried to head-off the Apple vs MS/Windows debate by stating that I am interested in spec's for a new "PC". "PC" usually is taken to mean a Windows species operating system. Ben's question:
was to the point. However, I have not experienced a NAA prejudice against PC's. I seem to remember NAA promoting a DELL machine pre-loaded w/ VW, a year or so ago. Also, VW tech support provided some good information re choosing a PC.Why would anyone choose to spec their PC based on what Apple sells? -
Thanks for the suggestions. I am looking to buy one that I spec from a manufacturer.
I am interested in suggestions for specifications for a new, high performance, pc for Vectorworks 2010 Architect with Renderworks.
Thanks in advance.
Thanks everyone for your replies. The quick keys work fine. Changing to a simpler workspace did not make a difference. Quick keys it is.
Vectorworks tech guys: any suggestions? Is this a known bug?
If I have multiple files open I cannot switch between them by choosing them in the Window drop down menu. Is anyone else having this problem?
How do I use constraints in VW2010 to keep door set distance from wall?
in General Discussion
Posted
I agree with that.
