C Dorman
    4
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect
  • Location
    San Rafael, CA
  1. Sorry, I must clarify, 1 autocad unit is 12".
  2. Try This: Open a blank file, don't modify anything, open the import dwg dialogue and set it for the dwg format that you are importing. In the conversion scale, set 1 autocad unit to 12 VW units for the conversion of feet to inches. Then set the scale manually to 1" = 8'. This should automatically import the drawing at 1/8 scale. Hopefully this works, I've found that at times it doesn't. Good luck.
  3. I have been reading about the video card crash, but I have been having many more perplexing crashes than that. Does anyone have info on: If I create a group with arrows (arcs with arrows on the end) together and then select one arrow and use the command flip horizontal, all of the arrows in the group actually flip. This I have been able to reproduce, however what I can't reproduce is the problem where all of the sudden all of my arrows in the entire file (including plans, elevations, sections at different scales) are reversed. Luckily I had discovered the work around, and I grouped everything on the layer and selected one arrow and reversed it and all of the arrows reversed, but I have no idea what triggered the global reversal. My biggest problem lately is that after about an hour of using VW, if I haven't remebered to save for at least 20 minutes, I will click-drag an object (to duplicate it) and VW crashes. It seems to be calculating something as I can move the mouse, but I have waited 20 minutes before and it still is crashed. These are the most easily traceable crashes but I have been crashing about 3 times in an 8 hour day with v.8.5.2 and I'm wondering if I should go back to 8.5.1. Also, in our offices fear of change I still have OS8.1, and I wonder if 9.1 would help or hurt. With 384mg on a G3, I would think that I'd never run out of power. Any suggestions would be welcome.
  4. To follow up on the Workgroup referencing problem, at the least, VW should associate all paste in place commands, and Workgroup reference insertions with the origin rather the page location. I actually have found an added bug that if you have some layers in a 3d view and you move the page, it changes the reference point on those layers and all the sudden the layers no longer stack or align. I have also had the problem that is not as serious where if you undo a page move, every object on every layer is selected. We have a running joke about this in the office because sometimes it takes 5 minutes for a slower computer to recalculate the locations of every object in the file. I don't know if you will see the connection, but in the end I think that all of these problems are related to the fact that VW computes object locations based on the page rather than the origin. Naturally, I am greatly looking forward to a new release.
